Defeated by a bolt
So, after buying the new suspension bits, I thought I'll get the car in the air and start fitting them.
So, the Rear Upper Control Arms are on. Had to hear up the bolts to crack them off etc but I managed in the end. Didn't do the hicas delete as I thought I'd probably have to take the knuckle out and press the old bush and ball joint out and I didn't have a press there so left it for another day.
On to the front, I started with the tension rods, managed one side without any real issue, the other side ruined my life!!! The bolt that goes through the bushing just will not come out, we got the nut off the end but no matter what we tied, hammers, heat etc the bolt wouldn't come out so must be corroded inside the bushing.
Anyway, I'm gonna have to cut the bolt, so anyone know where is best to get replacements?
I have to say, having bought pretty much the most expensive parts you can, I think they should come with new bolts tbh
Membership No 0780
INSURANCE GOOFA
That's a real pain, I think they should supply bolts, I will have to order a set when I replace mine, nothing worse than a new part and old bolt.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
First off its a specific bolt made for that job, the only bolt you can get to replace it is a genuine one, secondly DON`T CUT THE BOLT !
If you have not already removed the whole assembly from the car do so, undo the two 14 mm bolts up into the chassis rail, and the two 17 mm into the member under the radiator and now it is on the floor its is easier to deal with.
Rather than beat out the bolt, you need to turn the bolt, you will need some kind of vice to put it in, drown the thing in WD40 and get that bolt turning with a breaker bar, it will release, never had one not release before. If you do want to remove it from the car you cannot get a socket on the head of the bolt due to the inter-cooler location but a really good ring spanner would and give it some heavy clouts with a hammer to break the rust and may work but not so certain.
Once removed the bolt will want a good clean and grease before using.
Jeff
I think they should supply them because it makes sense the old bolt would be sh!t
Membership No 0780
INSURANCE GOOFA
We had the whole thing off the car mate. I didn't have a vice there but did try a socket on the other side. We could turn (breaker bar) it but it wouldn't put out at all. I'll perhaps get it somewhere with a press maybe.
Do you know the part numbers by any chance?
Membership No 0780
INSURANCE GOOFA
OEM Nissan 300ZX Tension Rod Bolt
Part no 54475-15U00 > 54475-35F10
Actually only a tenner or so, might be worth get one then and cut yours after all.
Jeff
Jeff
[ATTACH=CONFIG]96974[/ATTACH]
Is that 2 different part numbers?
Membership No 0780
INSURANCE GOOFA
Left and right bolt.
Na not really !! ha ha ............ original part number and possible later part number.
Jeff
Jeff
Why would it be a different number for the passenger side to drivers side? Aren't they the same?
Edited by bird
Membership No 0780
INSURANCE GOOFA
:clap::rofl:Hahaha... Just seen the bottom of your post... Got me
Membership No 0780
INSURANCE GOOFA
Love it !!
You know where I am if you need any help !!
Jeff
Love it !!
Jeff
I do mate... On a god damn beach working on your tan haha.
Thanks very much mate. Appreciate it as always
Membership No 0780
INSURANCE GOOFA
had this on a evo X ....a G-clamp made it fly out.
get one with a big enough socket and you are away....and before i got the clamp i could get a decent swing on it with a lump hammer too...g clamp took like 2 mins
Certainly worth a try mate. Would it need to be one of those fat ones?
Membership No 0780
INSURANCE GOOFA
Just one with the ability to go over the bolt and socket. with a socket wide enough to go over bolt head.
That size is pretty beefy but yeah, the beefier the better. Will make mince meat of it.
My neighbour has a bench and vice, I think that could be a good shout.
Membership No 0780
INSURANCE GOOFA
G clamp means you can do it on the drive under the car but yeah pretty much the same process.
Jeff
Do you know whether the bolts come with the nut Jeff?
Membership No 0780
INSURANCE GOOFA
Nut is a separate part number 01223-00281 price is £1.20
Jeff
Thanks mate. I've just bought 2 of each (Bolt and Nut) for £16.22
Membership No 0780
INSURANCE GOOFA
Just seen this Lee,i would have posted ya a set up if you asked doh !
Thanks very much Jimmer, I hadn't thought to ask but I will in future if you stock this kind of thing. I have started on the front upper control arms yet lol.
Have some rep for your kind offer though, that's great!
Membership No 0780
INSURANCE GOOFA
