does anyone know how to get the ignition barrel/lock out? it just looks like theres no way of getting it off.
thanks
phil
You need to put the key in and turn it to the I position, then once you remove the harness it should just pop straight out.
If you haven't got the key or lan to replace it, ram a screw driver in there and thenturn it to the I position.
Don't ask me how I know that, I grew up in Dagenham ;)
cheers mate, bt what do you mean by harness, ive took all the plastic connectors off and the steering wheel!!?
cheers
phil (the dil)
An ignition barrel always has a harness. The barrel is the section that turns, the harness is the solid metal bit that holds the barrel.
es, thats the bit(the harness)that i tried to get off,is it welded on or something?
