I found this on TT.net
See how you do, but 1 or 2 of the answers are a little iffy to me.
Easy
1. Will 2+2 targa roof segments fit a 2 seater?
2. What is the size of the bolts which hold the centre nose panel on?
3. The VG30DETT engine is used in what other cars?
4. Which are bigger, the rear or front brake disks?
5. Would a 2+2 NA in 3rd gear at 3500rpm be doing the same speed as a 2 seater TT in 3rd at 3500rpm?
6. In which countries other than Japan was the Z32 labelled a Fairlady?
7. What Mitsubishi part is frequently prone to error on the Z32? (asking this cause my Magna loving brother is sitting here watching me )
8. Which has a better weight distribution, a 2+2 or 2 seater?
9. Which has a lower function of polar momentum, a 2+2 or 2 seater?
10. How many O2 sensors does the Z have?
11. What is the standard boost pressure (in psi) of a stock TT?
12. Excluding any lights or components on the dashboard, if you were to turn on all interior lights in a 2+2 how many would be shining?
13. Name 5 changes made to series 4 Z's.
14. What impedance spark plug leads are used on the VG30DETT?
15. What is the highest number on the tachometer? (not redline, but the very maximum)
Medium
Some tricky ones in here.....
16. Name 3 cars (by model number!) which have inheritted/shared the HICAS 4 wheel steering system
17. What light (on some models only!) is located in the middle area where the indicator and high beam lights are placed on the dash?
18. True or false? The Z's chassis is actually designed for a mid engine layout. This idea was abandoned but the mid engine chassis features retained.
19. Fill in the blanks: According to the designers "The Z was designed to compete with the American _________ in terms of performance but still be as easy and enjoyable to drive as the European ___________" (both are cars)
20. In what year and month did the series 4 (new front bar, rear wing, interior changes) take place?
21. Which company makes the Z's brake calipers?
22. What is the coefficient of drag for the TT 2 seater?
23. What is the coefficient of drag for the NA 2 seater?
24. What is the ECU error code for a faulty Crank Angle Sensor?
25. Standing in front of the Z facing the engine, on which side are cylinders 1, 3 and 5?
26. Why was the V8 engine from the Q45 Infiniti not used in the Z as some designers had originally planned?
27. How many speakers would a US Bose sound system equipped Z have if released in 1990?
28. Name a part on the Z31 that is also used on the Z32.
29. What is the bolt size that holds the brake caliper to the mount at the front brakes?
30. Can a left hand intercooler be used on the right hand side in a TT?
Hard
Questions off the top of my head, many won't have been ever on the forum, some probably require you to have read a 300ZX book. Hey, that's why they're hard!
31. What is the angle of the V in the VG30DETT?
32. What was the code name for the Z during it's design?
33. True or false? The Z had the most angled windscreen of any production vechile at the time of it's release.
34. Which design team is responsible for the shape of the Z32? Nissan California or Nissan Japan?
35. In Japan, was the Z32 sold at Nissan or Prince dealerships?
36. What variant of the Z (by country) has the softest suspension?
37. By how much does NVICs advance timing on the intake cams at higher revs?
38. In standard form, what car makes more power per psi of boost pressure from the following list of cars:
Mk IV Toyota Supra, R33 Nissan Skyline GTR, FD series Mazda RX-7, 993 Porsche 911, Mistubishi 3000GT, MY 99 Subaru WRX, Mistubishi Lancer EVO 6, or Z32 Nissan 300ZX Twin Turbo.
Have fun and no cheating by looking at other's answers :)
Stuart
Stuart
Are we talking Auto or Manual here???
LMAO!! :D
Sorry....couldn't resist...
Robert.
  • 4 years later...
1. no
2. 6mm
3. none the tt engine was 300zx/fairlady specific the non turbo or single turbo was used in other models.
4. rear
5. no
6. none it was the nickname for jdm cars. it was marketed as the 300zx
7. series 1 ptu but the cas is a mitsubuisi part also
8. 2+2
9. wtf!!
10. 2
11. 9psi?
12. 6
13. airbag, no boost guage, remote locking, iron/steel calipers
14. what leads the z has individual coilpacks
15. 9000 rpm
16. Q45, r33 gt-r,r34 gt-r, infinity
17. automatic transmition light
18. unsure.... true as a mid engine development was on the cards.
19. mustang .......
20. ??
21.
lol, 4 years later...
question 38 is interesting. it sounds like a leading question in a Z quiz, but id stick my neck out for the Poopra.
Easy
Medium
Hard
Stuart
Off the top of my head..
1. no
2. 12mm
3. none
4. Rear
5. no
6. none
7. PTU
8. 2+2
9.
10. 2
11. 9.5psi
12. 3...or 5 if u include glovebox and boot
13.
14. Does'snt use spark plug leads
15. 8
__________
16. R32, R33, R34
17.
18. False...there was an early prototype called the Mid-4 though
19. Corvette, Porsche 944
20. 8/94
21. Summito
22. 0.32
23. 0.33
24. 11
25. Left
26. Becuase of development costs and becuase competition were using smaller turbocharged engines....shame :(
27. 5
28.
29. 14mm
30. No
_________
31.
32.
33. True
34. Japan
35. Both
36. Japan
37.
38. 300zx
