ive recently had a RPS 6 puck clutch & fidanza flywheel fitted to my car, after having it fitted the car would not start. at first it was assumed ther was a problem with the mounting of the starter motor as the bolt holding it in place had stripped the threads in the hole where it is located.
yestarday i helicoiled the hole and fitted the starter tight against the gearbox. the car still wouldnt start. i took the starter of and had a look, after inspecting i am now sure that the starter motor is too close to the flywheel, and is hitting the flywheel instead of meshing with it.
has anyone else had this kind of problem when fitting uprated clutch & flywheel? or any suggestions to rectify would be much appriciated
cheers
aki
