Fao noz
Hi Noel,
you mapped my zed a year or so ago when it was an auto, im having it converted to manual soon and wondered if it needs mapping again or if its safe to drive under the existing map. im guessing as its only a change of gear wether thats done by me or a computer souldnt matter but just checking in case?
Also read a thread on here that you run without recircs or bov's, is this safe on stock turbos 17psi, as im considering this myself to eliminate goosehonk and i dont mind the pigeon flutter noise instead. ?
Jon
Hi,
Can you send me some details please so I can look up your file on Monday. There won't be an issue, just need to be 100% before advising you further.
Contact details will be in my signature beneath this post :)
With regards to running without any kind of pressure relief valve, there were no issues whatsoever on my car at a peak boost pressure of 25psi on stock auto turbos.
Thanks noel. Messaged you through Facebook...
Thanks again.
Located your file. No issues running the map when converted to manual :)
