My cars winking at me!!!!!
Before I start volt dropping earths and etc I wondered if anyone has experienced this
My o/s/f head lamp flickers on and off, mainly after being used for some time,
Goes off when relay removed, but returns when refitted/ swapped with n/s relay so I do not think its relay
flickering lights on and off it eventually stopped but cant say for sure if it was me or just a coincidence?
happens with ignition on and off
Yep i had this and know exactly what you need to do :thumbup:
With the Passenger kickpanel removed you will see some connector blocks up on a bracket, there you will find once taken apart green corrosion on the pins/terminals of the plug, clean these out and your problem will be sorted.
I had a few corroded with green gunk, which also made my horn go off every now and then on its own and of course that is also cured :thumbup1:
I came back from holiday to a flat battery, once started i never noticed the headlight on as it was night and needed them on anyway, it wasnt until i stopped at my destination and turned them off, key out and a few seconds later the headlight came on and stayed on, sounds like yours is heading the same way lol
that's great, thanks i'll give it a go,
may also be why horn didn't work when I purchased, (bodged to get through mot lol) :thumbup1::oops:
