Manual Conversion Kit
Selling up as i'll be putting the slicktop up for sale after the winter and won't be doing the manual conversion on it.
Come complete with:
  • Decent manual gearbox
  • TT Flywheel
  • NA Flywheel
  • Clutch Pedal
  • Gearbox dust shield
  • Propshaft for shorty (manual front can be bolted to any rear end LWB or SWB)
  • Clutch master and slave cylinder
  • Various new bushes and seals for the linkage
  • No clutch included but do have a worn 6 puck racing clutch that needs new clutch pads fitting that could be included for the right money
  • Other parts but will confirm when i've had a look through this weekend
Quick sale needed to finance another project, buyer to collect or will deliver for a fee
Pictures to follow when i empty out the shed this weekend
£350 or best offer
Edited by bantambunny
As far as i remember yes, i think the bellhousing is as well
I got it from Daffy who was going to fit it to my car before he sold it
EDIT: I believe from what i've read the transmissions are the same it's only the bellhousing that makes a difference and the rear diff is differently geared to give shorter ratios on the NA - NA bellhousing will fit the TT flywheel but will need a little bit grinding out and some shims on the starter motor to fit but that's the only differences.
As far as i remember this is a TT bellhousing but i have had it in the shed for a couple of years now so couldn't say 100% unless someone could tell me the stamps on the NA/TT bellhousings to check?
I was fitting this to a TT shorty though
I have a N/a manual fitted over my TT flywheel on my vh.
As you said buddy, i needs a bit of grinding which takes no time at all as its Ali. There are instructions on the web about where to grind and so on. With regards to the starter motor you can by a shim plate already but i just used 2 washers.
It's an NA Nick. But I bought the starter shim from the States. Should be in with the other parts. As said above, the bell housing just needs a slight modification which is easily done and been done before many times.
Daffy.
Thanks guys - there we go then it's an NA box and bellhousing but will fit a TT with no problems.
