November 20, 200224 yr The zed standard is 0.9 bar?!?!?! What is a safe ish pressure to take stock turbos to. And can this be done by cat removal and correct diameter straight through pipes being fitted???
November 20, 200224 yr Nope its not its around 7psi saftey boost 9psi stock boost. 1 psi = 0.06895 bar so its around .62 bar. safe id say without an ecu is around .8-.9 bar no more.
November 20, 200224 yr I got confuzled. Standard is 0.9 PSI, What is a safe ish PSI to take stocks to. and can this be done removing the cat's and looking into the back pressure etc Cheers
