Indicators not working
I have noticed that my indicators do not work. My hazard lights used to, but now don't. Please can anyone advice my on what to check. Someone said it could be the flasher unit? How do I find and check this?
The flasher unit is above the knee panel under the steering wheel, do you here any clicking from the relay?
The hazard switch is a main part of the indicator loom, check that the plug on the rear of the switch is seated fully and also check the fuse in the drivers footwell.
Yeah, like Groover says and both fuses (there are two, one for indicators and one for hazards), check the hazard switch isn't half on, that will affect the indicators.
ย
check all the indicators for corrosion or damaged wires causing a short.
