Me again.
So I have two questions:
RobHowl ·
I have the same wheels that's on this car, i need a center cap but don't know the make of them to is if it's possible to get hold of one/set.
I sent the seller a message asking him/her what make they are.
They haven't replied back probably because i asked about the wheels and not the car.
If anyone knows the car or the make of these wheels i'd greatly appreciate it.
http://www.ebay.co.uk/itm/Nissan-300-ZX-Twin-Turbo-UK-Spec-Manual-/351099022474?ssPageName=ADME:X:AAQ:GB:1123
