Oil seal VVT camshaft?
Think the title is right can't remember it was so long ago
Not sure what there worth £7.50 posted?
They are for sealing behind the cover plate which houses the variable valve timing spring on the front of the intake camshaft.
It can if severely worn, although more likely a cam seal further back behind the cam sprocket can leak. When you take off your cambelt covers, you would be able to see more clearly if or where you have an oil leak.
:thumbup:Thanks for your input Graham
Edited by bigh
Spelling
