ECU Wires
Hi All, Can you guys tell me if this wire should be connected to anything ?.
I'm half way through fitting my TC and not sure if I pulled this out of something or it was just there on it's tod.
If it's coming out of the ECU connector then yes.
Thanks Chris.
Any Idea what it should be connected to ?.
I finished fitting the traction control and the car seems to run ok, everything works, but this wire is still not connected.
If you tell me what terminal connection numbers the
white wires are connected to , I`l tell you exactly where they go to.
Mark
I found out the hard way. I connected the wire back to itself and I now have a speed limit of 112 mph. So I guess the red wire from the speed defended was connected to this wire. I will splice the red onto the white and see if this sorts the problem out.
Connection was 60 from ECU.
According to the manual:
Wire 60 (which is BLACK) goes to several earths including
engine earth
Wire 59 (WHITE) is also connected to 49 and 109 and goes to
the CAS , AFM and the ECCS relay.
