- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Have a look at this dyno chart(need tt.net login however):
http://www.twinturbo.net/cgi-bin/ttnet_viewmsg.pl?forum=general&msg_id=717721
If you cant access the tt.net post:
Original Japanese dyno sheet:
After Kuah input info into a spreadsheet, converted torque numbers, proper dyno sheet plotted out:
746.5 RwHP (5th gear reading as 4th gear produced to much wheelspin)
600+ LB FT
Quote from Kuah's post:
What is most impressive was how the power holds all the way to redline. Couple things to note:
1. Engine had Tomei solid lifters, Tomei hi-lift cams, Tomei 89mm forged pistons.
2. This was at 1.5kg/cm^2 = 21PSI, on Japan pump gas, which is about equivalent to 95 octane(US rating) here (note: their 100 octane is based on research octane rating, we do not use the same octane rating system). Imagine this car on high boost/race gas :O
3. This is using the 8cm^2 housing, which is small for a TD06-20G.
BTW this car was featured in the HyperRev book. I scanned in that page, it can be found here: http://splparts.com/Tuners/Pentroof/hyperrev.pdf
Looking at the Hyper Rev pdf it also had 6x550cc injectors and 4x360cc injectors.
I think it also had an OS Giken gear kit(still 5 speed).
Oh and this was done in 1997 it seems. :D
