Well, i got the idle issue sorted. one side of the engine had no screw adjuster ting in so the engine was opening one bank before the other. Also, somone had adjusted the throttle cable to keep the revs higher so the end was slightly off the rest ledge.
Having sorted this, the engine is now hunting for revs when the throttle is at a steady position? ie: throttle held at 2000rpm car hunts between 1500rpm and 2000rpm.
Any ideas?
It used to do this slightly (very slightly) but not as noticable as it is now that i've had the idle revs sorted.
I get the feeling that whoever had the car before me has messed around with the car somewhat trying to soprt problems (or to adjust settings so that problems weren't as evident instead of fixing the issues)
Hi All,
Any ideas?
Peter
