tt and na heads.
Are they different? I know the cams will be, but are the heads themselves?
Been researching cams for my na, and it occurred to me I could rebuild my tt engines head
TT heads have larger porting .. and valves are made stronger
you can use tt heads on an NA engine
n/a heads have slightly different flow pattern and i believe do flow better than tt heads if they are built to same specs ie bigger valves port work etc but on a n/a thats not trying to make loads of power either will be fine
