Rear Suspension Parts Interchangeability
Hi there, needs some advice....I want to change my TT rear suspension to a NA setup (non HICAS)
My question is will my TT "a" arms, upper arms and the link arm (not sure of the correct names) fit the NA sub frame and NA bearing carrier? I have deleted HICAS on the TT already.
Reason is the NA "a" arms, upper arm and the link armare quite corroded as it was a coastal car and the TT ones rust free and have poly bushes fitted.
I dont have both subframes on the ground to visually compare.
Thanks for any info.
Yes, they are all the same. The differences are the frame, diff, prop shaft, half shafts, bearings and hubs. Hicas delete arms may or may not fit, depends on how its been done.
