Brake disc help??
Hi guys
Just got my first 300zx, pretty pleased to say the least but it is a project as a few bits and pieces need doing to it and i need some advice from you guys on here
so on the last mot the advisories were:
Slight corrosion on both rear brake discs
Both rear tyres have low tread
Slight blow on front exhaust pipes
Oil leak on engine and gear box
Slight corrosion to rear metal brake pipes
Slight corrosion to front metal brake pipes
Slight corrosion to Front to Rear fuel pipes
So the car is declared sorn as i have another car to drive around in and this will be my project to fix up.
The wierd thing is my car is an import, however, it is a Z32 3.0L V6 non turbo manual 5 speed. I understand that this is not usual? it is also a 4 seater.
so basically my questions are will parts on the internet where it states twin turbo be okay to use on my car?
im pretty confused at the minute haha real newbie i know.
if anyone knows what brake discs i can get would be a great help and if there are anything else i amunsure of i am hoping i can post on this thread for some help.
at the minute any help would be appreciative.
Thanks.
Kieran
  • Replies 33
  • Views 1.3k
Ah right okay great well i will go round the the garage tomorrow and size them up to see if they will fit
when it says 297mm x 18mm that 297mm in diameter and 18mm thick?
the car was registered in japen in 1990 but came into the uk in 2004 so do you think they will have different sizes on the front?
Thread moved into Help and Advice section. :)
Oh, and welcome to the forum matey :)
Edited by Steams
Probably smaller on the front, 26mm. If you want to change the front then would be worth doing the twin turbo caliper upgrade
could anyone tell me what grade oil i should get?
and spark plugs too
  • 3 weeks later...
Does anyone know where or who is selling some front brake calipers from a TT
I've got a set from a 1990 TT with pads in great condition £80 + delivery
forget someones advisory from there last mot, before you spend out any moneys put it in for an mot yourself then go from there. but the time you get there your rust from brake discs at the back will have gone. get your fresh mot then you can prioritise the moneys first mate. thats my advice
Are they the 30mm ones too
I have brembo pads ready to go but I just need the calipers
So how much for just the calipers
@spindoctor
I can't get an MOT yet because I can't get it taxed or insured
I'm only 19 and it's just a project car for me
I'm hoping next year I can insure it or maybe get a few months insurance through the summer so I can get an MOT and Tax
Yes, they're 30mm ones. Not going to sell without pads unless someone wants to buy a set of oem pads separately. So still £80.
Okay well I need to figure some stuff out but I'll definitely let you know whether I'll have them or not
I just need to speak to my dad
How much for delivery or is that included?
If all the discs have is some light corrosion then you could just remove and shot blast them. Paint the surfaces that are not touched by the pads and they would look fine.
I've already noughts new discs and pads
Just waiting to hear back about these calipers
@Shortz
I'm interested in buying your calipers could you get in touch with me as soon as you can please
@spindoctor
dont need a car taxed or insured to drive to a pre booked mot station and back home.
Really? So if I book it in advance what do I do get a paper that says where I am going?
You need an MOT to tax your car. You need insurance to drive your car there.
Sent from my iPad using Tapatalk
