air flow meter
Just wondering if it is possible to resistance check the air flow meter on these car's? :)
Not sure about a resistance check, but there is a voltage check that may help.
If you can peel back the outer rubber cover of the connector attached to the MAF itself you can take a voltage reading between the second wire in from the left as you look at it and ground.
With the engine up to temp with ignition on but engine not running, you should get 0.8 volts.
Engine idling you should be getting between 0.8 and 1.5 volts.
Hope that is of help.
