Uk series 2 clocks into a jdm series 3
As title does anyone know if they will fit ,the plugs are the same but the circuit board on the back looks different had a search but nothing conclusive anyone know for deffo ta
Jim
as far as I know there are only two configurations for the plug setup.. Series one then Series 2 & onward..
if you look in the service manual it shows the two, they are incompatible unless you rewire.
so if your plugs and sockets have the same orientation and fit then go for it.
with any luck someone more experienced with these matters will pipe up.. :)
Plugs are the same so will plug and play, there will be differences in the look of the rear fische board, but functionality is the same.
Thanks for that :pint:
