Had a reputable machine shop do some machining for me and took delivery yesterday for starting the assembly.
I asked for the block to rebored to suit my 88mm Wisecos as well as the decking of the block to be trued and finished (AR50) for Cometic (.045"/1.2mm) mls head gaskets.
All looked good until I checked to see that I got my original block back by checking the engine numbers and ...well the engine numbers are very feint to gone and worried that too much has been taken off. Any suggestions here? Barring that I have no numbers on the block which will raise law enforcement eye brows.
My main concern is with the possible excessive decking, I thought first step would be a trial fit of the bearings, crank, rod and piston to see if piston is in or out of the bore as I know that the VG30 is a flush/zero piston to deck. This I have done and I have a situation where the piston is out of the bore by .152mm or .006".
Is this going to pose a problem with respect to any mechanical interference etc.
Hi, I have an issue which is worrying me at the moment concerning my build with the following major items.
Wiseco pistons, eagle rods. cometic HG, Z1 GT675 turbo kit.
I value any feed back, thanks
