How to fix a zcentre dash mount 3 gauge pod
As above can anyone recommend some sticky stuff to stick down the front edge of the centre dash gauge holder I am fitting , it has 2 tangs that hold the back down I just need something to hold it in place basically
Cheers Jim
what one you got the v1 or v2 as the v2 one got 2 long bolts
V1 mate
you have to have the v1 Bonded on the front bud
I know ted thats what I was askin if anyone knew what I could use to bond it in place with mate
try no nails you can get that in a clear and you can use round the house when your wife if like mine have bright idea's
I used to have one of these. Fitted it with clear silicon.
On a hot day the silicon ran down the dash
[sIGPIC][/sIGPIC]
wrong type of silicon :)
halfords do a black silicon sealant, which would be better to use as it blends in with the dash as it is.
I used a 2 part epoxy glue, but the black sealant would be a better option IMO
Thanks guys
I've got to stick mine down yet, was going to use black silicon like vods says. Like the idea of the two tangs at the back though, mine doesn't have them. Will have to fit some to mine I think.
Definitely worth adapting the version 1 pod Dave, as there isnt much of the lip to glue/seal on the rear, front is ok though.
