failed mot on emissons
they done a pre cat test and it still failed. it was 6%. Could it be because i removed carbon canister ? or timing is incorrect ? i replaced cas and had no timing light but i marked it put it in the same way. How to reduce emmissions :) thanks
I might forgot to plug it in after respray :) going to have a look :)
what are they doing the test as?
Don't know. Just pre cat test
pull the pipe off the balance bar but dont block it, or undo another of small vacuum hoses dotted around the engine, as long as it makes the revs increase you know its one to do. then take it in, make sure the disconnected pipe isnt visible. it should pass a non cat test. Or so ive heard.
Then get it sorted for the next.
