hicas info
my car pulls to the left i have try all kinds trying to short it is it possible that the hicas is faulty so as in i track the car its all straight on the machine and when i start the engine and go to drive its turns the rear wheel to one side like when the engines off no oil pressure is going to it and when i start the car it get pressure and pushs it to a new position? i know its only ment to work of say 30 or 40 mph but is it poss the oild pressure it sending it across to one side rite from starting the engine and this is why the car it pulling to one side
I would be more likely to think it was one of the ball joints but if you have checked them all then I guess it could be a issue inside the system.
The HICAS eliminator bars that screw directly into the existing arms are only about £70, well worth doing and getting rid of it.
http://www.zcentre.co.uk/index.php?option=com_virtuemart&page=shop.product_details&flypage=flypage.pbv.tpl&product_id=236&Itemid=7
http://www.ebay.co.uk/itm/NISSAN-300ZX-Z32-TWIN-TURBO-REAR-HICAS-STEERING-RACK-REMOVAL-LOCK-OUT-BAR-BRACE-/350794777691?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item51acff845b
you will also need the parts to eliminate the lines.
http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.244
is there any way i can some how turn the hicas off like temp just so i can drive it up the road to see if that works thinking may i could clamp off the to hydrolic pipes near the unit its self
