engine timing info
when uping the boost to 14psi should you leave timing at 15 of does it need to be ajusted
The basic idle timing will stay at 15° when the engine is warmed up mate.
The only reason to change this is if the car is tuned to something different and it general isn't even changed when tuning
Membership No 0780
INSURANCE GOOFA
ok i see is it a good idea t get a timing light at see if its set correct then at 15
Yes, but you'll only get the 15° once the engines warmed up mate
Membership No 0780
INSURANCE GOOFA
ok thanks will have to get a timing light and see what it says
Good Luck. might be worth seeing if any local members have one you can borrow.
Membership No 0780
INSURANCE GOOFA
well that would be very good
