Engine mounts
Can I change engine mounts if the engine is still in the car ? Is if enough space to change them if I just lift engind a bit ? Is if enough room to undo the bolts?
Thanks.
yes u can do it ... but you will have to drop the alternator to gain access to the upper bolt on that side
lift the engine from above or jack it up on the bell housing of the gear box .. Not the Sump !
drop the subframe down a little by undoing the bolts by about 1/2" .. this should give u enuff space to pull them out once bolts are off
Now I am strugling to get passanger side off. I took alternator off but still cant reach a bolt its too tight and not enaught room to turn
Passenger side will be the AC pump there ... u can gain access from top or bottom ... you gonna have to keep trying m8
Ohh sorry I mixed thing i cant undo driver side one. Alternator is removed but still cant get do change lol
