Thanks Jeff
Hiya Jeff just thought id put this message up,then you can see where i am comming from. You said on the phone this morning that the cam belt was done and was straght forward. I am asuming that it hasnt been pluged in yet to the consult yet due to having no brakes still yet. I done well putting the wrong fluid in in the last min so i could move the car about me drive.
Back to my list then i think by memory i have
Cambelt, power steering belt, alternater belt. straghtn up steering wheel, reseal joint on exhaust offside mid, check ive done up /torqued up bolts on rear diff, them alan key things. top up gear box oil, i think im 0.5 ltr short. bleed clutch.
Then i think its a blast up the road to make sure everything is all ok. when you get to that stage can you turn on my e.b.c that seats under steering wheel on the left to put in the correct settings so i dont have to muck around with it ,so i can just turn it on safely knowing im not going to blow anything up. Or at least lessen the risk.;.
Then its just a last look over or a pre mot if you like just so when i get me car back im not going to get anymore suprises, when i get it home cas when home its straght to the bodyshop then mot. but if there is something that may need doing i think you might as well do it rather than someone else. Pending what it is and how much.
Dont think ive missed anything apart from to say thanks to you all, for your help and advise.:yes:
No posts to show
