na subframe questions lwb to swb
Hi i picked up a complete rear na subframe inc hubs etc yesterday[thanks tomomotana] i have 2 questions i take i need a swb rear section of the prop as it came off a lwb is this correct also can i use the lwb rear section off handbrake cable or do i need to use my swb one thanks taff .:thumbup1:
I think you need the n/a rear section of the prop in whatever length you need (swb/lwb) as the n/a prop is 4 bolts to the diff and TT is 5 bolts. As far as I'm aware...
Yep, you'll need an NA rear SWB propshaft (or a NA Manual 1 piece propshaft), and use your own handbrake cables.
i might just happen to have one of those for you, as im looking at getting a one piece. how soon do you need it?
Yer ill def have it mate no rush I've got to have subframe powercoated and re bushed as yet .I take it you have a na subframe fitted then .
