protoj · Tuesday at 18:48 2 days
Vidal Baboon has organised an open rolling road day for those interested in the South Wales area. Probably going to be around £35 per car unless we get more in by the weekend. You can just turn up and pay on the day if you don't want to put a deposit down but be aware that those who have put deposits down will be running first!
GotBoost Performance Tuning Ltd
Unit 2 Rear
Litchard Industrial Estate
Brackla
Bridgend
CF31 2AL
07943 368500
sales@gotboost.co.uk
Sunday April 14th 2013 from 10am
See SXOC post about it for more information.
