After changing both 02 sensors and checked a few other things, I thought I would run Data Scan just to check.
As far as the sensors go, all appears to be good.
Would someone take a look and see if everything else seems correct?
[video=youtube_share;kbN_e6FoIKY]
Sorry about the quality, Will try again at the weekend.
All appears to be OK. You might want to just check that the base idle is set up correctly. Unplug IACV (yellow connector) and adjust the screw until idle is 650-700 RPM with no electrical load and the engine up to temp.
Cheers Noz. :thumbup:
Really appreciate your feedback.
Out of interest, what was the main readings that indicate adjusting the base idle?
It's just that I would like to understand how all of the readings affect each other and how they work together.
Just that the idle RPM dropped a tad low a couple of times, nothing major :)
Cheers Noz,
That might explain why sometimes after say, pulling up quickly at a roundabout, the RPM would dip quite low and then recover.
