Racelogic analog control box, launch control
Does anyone have a Racelogic traction control system installed with the analog control box with the launch button on it? if so can i ask a big favor, is there any chance you can take the back off the control box and see what the rear of the button is like, i want to add the launch button to mine, which if im correct is just a momentary switch.
I know i can get the analog control box with the button already on for £65 from racelogic, which would make it a plug and play affair, but if its just a button i need, then i see no point in spending out that much, just for a button. would also need the pin it connects too on the racelogic ECU.
This is the same control box i have.
This is the control box with the launch button on it.
Just need to know if there is anything special about the button being used and what pins on the racelogic ecu it needs to connect too to make it work. i know the software is the same, as it is a plug and play affair, i just cant see the point in spending £65 if its just a button i need.
  • Replies 26
  • Views 4.3k
old thread but very nice read so if i have i got this correct you added a button to turn the launch on ?
