Testing Greddy Profec B Solenoid?
Does anyone know if it's possible to test my profec b solenoid, as I'm sure its causing a boost issue I've got?
The boost controller has worked perfectly since I fitted it 18 months ago, until recently. The car initially started boosting a lot higher than normal, so i adjusted the settings, which had no effect. I turned the controller off and still had the same problem. I've bypassed the solenoid now and the car is fine again, but obviously only running standard boost.
The display appears to be operating okay, so is there a way of confirming it's the solenoid?
See if someone local has a similar one to swap it and see if that solves it? I had a wierd boost problem and came to a similar conclusion. So just bought a new 1 from eBay. An official greedy one is expensive but I got mine for £45 I think.
Sounds like that's at fault to be honest.
Cheers.
Danny
I might just bite the bullet and buy one. The cheapest i can find on ebay is £72, does anyone know anywhere cheaper to buy one?
