I'm in the middle of having a plenum Modified and removing aload of stuff of it ..
Taken off the
bolt mounts
pcv valves
water pipes
Blocking off Balance bar ( removed )
Now the IDle control valve the balance bar Feeds it from the small pipe
throu the plenum and then back out in to outlet turbo pipe
do u guys think it will be ok to make a Internal hole with in the plenum
on one side to feed the idle control unit
all so is there any other info on this at all ?
No posts to show
