oil for my engine
Hi just double checking here.
Im going to use 10-40w running in oil for at least my first 2 oil changes on the rollers. Ive been advised to use full synthetic nanodrive 10-50w oil after its ran in.
What's the difference between 10-40w stock and 10-50w?
Also 5ltr should be more and enough for a full oil change on the tt shouldn't it?
Cheers Dan
4ltr is more than enough, it takes 3.0L in the engine and the filling the cooler will probably take another .5l.
10w-40 is a good all-rounder. 10w/15w-50 for 'high' power & track work for example.
The 10w-50 basically has a higher viscosity at higher temps. They both have the same viscosity at start-up.
Fuchs pro s 10/50 is a fantastic oil and all i use in my own and customer cars :)
