stock fuel pressure is?
Hi just double checking as ive set my fpr to 3.5 bar which seems to be standard though out. But I do remember hearing zeds maybe 3 bar? Does anyone know the correct pressure?
Thanks Dan
its in the online workshop manual, im not at PC now to check but I seem to recall it being 43.4 psi (3 bar), and raises 1 psi for each psi of boost.
Great thanks. Im using 740 injectors but im sure stock pressure will be fine for start up on base map?
3 bar with the vac line to the FPR disconnected.
