quick rev counter related question
my new zeds rev counter doesn't work, sometimes it reads something but not anywhere near what it should,
but my blitz R-vit is reading a correct RPM from the consult port
assume its just the counter itself that's failed, just want to know if the ecu reads from the same source as the dash, then i can rule out the sender.
thanks.
it will be the dash pod gone faulty as it reads from the ECU and u said blitz is working
Could this Mark be that calibrated adjuster I posted up about last week, I will state again that it was in the middle of it's travel :detective:.
long as its the same series unit it will work ..
Speedo will be out but other than that rpm/fuel/temp will work
