tv reception problem with surround system...
Any ideas what I can do?
TV working fine, good reception on all freeview channels (and freeview HD channels on TV directly). Hook up my new surround sound system (LG BH9520TW) and have a play with the settings listening to music and with a dvd, all fine. Stick it on the TV and first few channels I try say no signal, others have jumpy pictures and a few are fine. Switch off the surround dound system and I gett all my channels back!
No point having a semi decent setup like this if I can't use it for every day TV watching.
I've got a booster plugged in already.
Need to know a bit more of how you have connected it all up including any rf in / outs scarts, hdmi ,digital coax or any optical cables.
At a guess you may have an issue with the way it is inteconnected, some cables don`t have complete connectivity at all pins and some can be reversed if you get the wrong ones, as I said a little more info will help.
Jeff TT
Just set it up so its all very straight forward connection wise (no sky and my hd recorder just broke so no feeds going into the unit at all).
TV ariel to booster, booster to tv.
HDMI between surround sound amp and TV with audio coming via ARC setting.
...and that really is it as BR player is built in to the unit with the amp.
I tried removing the wireless card and unplugging the wifi unit for rear speakers and it made no difference, swithced the unit off and bingo I have a strong signal on all channels again...but pi$$ poor sound obviously as its just via the TV.
