White/Amber Sidelight Bulb Fitted in Indicator Lens plus Kerb Lights
Instead of having separate sidelights and amber signal in the front crystal indicator lens chambers, I now have just the one 57 SMD switchback chip bulb, normal amber indication when sidelights are off during daylight but with the sidelights switched on and you indicate they alternate between very bright white and amber, turn the indicator off and the sidelights are just that and stay lit of course on that one notch on the pod dial.
This gave me the smaller lens chamber free so I have re-introduced this as the JDM 'curb/kerb light', only really because I could basically as it's not bright enough to actually do the job !!
These are activated one side at a time when the dipped headlights are on and you indicate that corner :cool3:.
I could if I'd of wanted to had these stay on all time as further sidelights but were's the fun in that !!
On viewing the vid below keep your eye on the dipped as these are the trigger for the T10 kerb lights to work, the kerb lights do not work when hazard indicators are on which is the situation in the final shots.
Hope you like :thumbup1:.
[video=youtube_share;ZqN7Udy4rFQ]
Edited by phutumsch
Re uploaded youtube vid
No posts to show
