Drain holes in sills.
Hi guys,
Anyone know if there is any drain holes in the sills, mine has skirts fitted and can't see anything. I'm hoping the flood water isn't sat in there rotting the car from the inside!
take off either the rear interior panel or the trim in the footwell. you should be able to reach down and check for water in the sill from there.
there are holes that lead directly into the sill. use a strip of card and slide it into the sill, it will show what level the water is at if any.
I found cable ties the ideal thing to poke up and clear the drain hole:thumbup1:
