Aup just a few Cars and options on what the Lads was talking about
these Models start around £130 ish you all so need on top
Radio £38
Servo £9.99
Charger £25
Battery £20
will take a few days to build
The Nissan GT-R, fielded by the UK-based Sumo Power to compete in the 2010 FIA GT1 World Championship, now comes on the fun-to-drive TT-01 Type-E Chassis.
Specs and Features
1/10 scale R/C assembly kit.
Polycarbonate body of the Nissan GT-R included.
Side mirrors and rear wing are reproduced with separately molded parts.
Separately molded light cases included (separately available LEDs can be installed).
Sticker sheet and masking seals included.
Narrow slick tires (26mm width) and silver narrow 6-spoke wheels (offset +2) included.
TT-01 Type-E chassis features 4WD shaft driven bathtub chassis with 4-wheel independent double wishbone suspension and sealed front and rear differential gearboxes.
Type 540 motor included.
Tamiya TEU-104BK ESC included
The Toyota 86 has been a highly anticipated sports car since the 2009 Tokyo Motor Show. In 2012 the vehicle was finally released to markets around the world. In Japan it is known as the Toyota 86. In Europe it is known as the GT-86 and in the USA and North America it is known as the Scion FR-S. The new Toyota 86 R/C body is mounted on Tamiya's proven entry level assembly kit, the TT-01E.
Specs
Scale: 1/10 scale
Construction type: assembly kit
Terrain use: on-road
Drive-train: 4WD
Drive type: shaft
Drive line: dog bone
Differential type: gear
Suspension: fully independent double wishbone
Steering mechanism: bell-crank
Shock damper: friction damper
Shock damper material: plastic
Tire type: rubber
Tire tread: radial
Body material: ABS Plastic
ESC: included
ESC type: TEU-105BK
LED Light buckets: no
LED lights: no
Motor type: 540-brushed type
Bearings: plastic bushing
Chassis material: plastic
Sticker material: vinyl
Internal gear ratio:
Adjustable camber: fixed
Adjustable toe angles: fixed
Adjustable ride height: yes
Adjustable gear ratio: yes
Adjustable wheelbase: yes
Adjustable track width: fixed
Adjustable shock angle: yes
Anti-squat adjustment: n/a
Droop adjustment: n/a
Special features: Extra plated wheels included
Requires: 7.2 battery, charger
Requires: polycarbonate paint
Requires: radio gear, servo, receiver
Lightweight and user-friendly TT-01D based chassis for effortless assembly.
TT-01D drift-spec modifications include drift tires, adjustable suspension tuning, full ball bearings, sport- tuned motor, aluminum heat sink, CVA mini shock dampers and short springs.
4WD shaft driven bathtub chassis with coil spring damped, 4-wheel independent double wishbone suspension and sealed front and rear differential gearbox.
Includes electronic speed controller (TEU-101 BK)
Includes LEDs for head and tail lights that turn on automatically when the car is switched on. Add the TLU-02 Light Control Unit (ITEM 53937) for greater control of light operations.
Wide variety of tune-up parts are separately available to customize your machine.
Cheers Mark im going to see him in a bit, and will let him know, thanks for the info.
