Hi,
Im in the process of preping my Zed for big and better things, ive already taken the spoiler off but was wondering how to remove both rear and front bumpers.
rear bumper is easy, take the interior panels off from the inside of the car, there is a series of 10mm nuts, and 4 bolts (2 at each side) inside, then there is a screw on the rear out side closest to the wheel arch, also dont forget the plastic binding lugs under the car that hold the bumper to the crash panel (get down on your back and slide under the rear you will see what i mean)
Unplug the number plate lights from inside the car and feed them through the hole to out side the car.
Front bumper is a bit more difficult, undo the side lights will give you access to the 2 x bolts that hold the bumper to the front wing, undo the nose panel and remove 4 x bolds holding the front bumper to the nose of the car, there is also a screw at each corner near the wheel arch, same as on rear that holds it on, if you have the j spec number plate holder on the front that will also need unbolting to free the bumper.
Vodkashots I cant thanks you enough, much appreciated:thumbup1:
