brembro brakes
hi just got some second hand brembro calipers for my 300 can anyone tell me if the short brake line coming from the caliper is the same line that is already on the zed or is it a different bore got 2 lines with the calipers but had them into a garage to fit (its a long story) told them to refit the standard ones back but on getting the car back one of the pipes that came with the brembros is missing and justwondered if the standard 300 metal pipes fit or do i need to kick up a stink:angry:
For the R33 Brembo setup - the standard Z32 short brake line (caliper to flexible brake line) will fit the Brembo calipers. You will
need to slightly reshape the line as the Brembo caliper sits further out from the axle then the OEM caliper (~22mm).
-Andrew
