Bluetooth conzult
Anyone ever tried to use Bluetooth plug into the obd port?
Can you even get one to fit?
Membership No 0780
INSURANCE GOOFA
you can get an ODB to usb (via a serial) and you might even be able to get one straight to USB..... so you could then put a Bluetooth dongle on it.
sounds like a right pain... lol..
I extended my connection and it now lives in the glove box, so it's now close to where I have the laptop.
How did you extend? Just a longer cable plugged in to the OBD?
Membership No 0780
INSURANCE GOOFA
The Nissan Consult port, which is probably not ODB (and certainly not ODB-II) is probably not powered and not a standard interface so you wouldn't be able to plug anything "standard" into it. So I think you are pretty much limited to a cabled connection.
Yeah, like Andy says it's not really obd... but I know what you meant...
no there is no extension as such, I just got a load of wire, cut the connector off and then wired it back up but longer.
I soldered the block on to the extension but used block connectors back up under the dash as it would be a real pain to solder in that location.
