A Pillar Pod
Evening all,
Fitting my pillar pod but need some inspiration on how to secure it at the top. There's a hole that lines up with a female clip on the pillar but a screw don't secure it.
How have you guys done it?
cheers
I used a trim clip which expands as you screw the integral screw in, holding it in place. if that makes sense lol.
Must be a hefty screw Dave? Nissan screws off old bits of trim ain't big enough, just spins.
Fair one on grip fill but I want to do it properly and so I can remove it at a later date if needed.
proper 4 " jobbie came straight out the other side. its a bit sharp and looks crap from the out side but on the inside its mint :lol:
Mine is only a small screw 1/4" tops iirc?
I used a bolt and put a rusty nut on the end of mine, little tip for you there :lol:
hope you used a washer you cowboy :slap:
anything else you want to know? i dont charge much. lmao
Whats the flight velocity of an unladen Swallow?.....
african or european??? :rofl:
very good mate, glad you got it.....cant beat a bit of classic Python :)
He can't answer you, Tim has throw him into the abyss :lol:
