Manual to auto conversion parts list
So i wanted to compose a little list of parts required to swap from a manual to auto. Can someone confirm and add what i miss
autobox
flywheel
torque converter
gearbox wiring
auto ecu harness?
auto gear stick
brake pedal maybe
auto prop
control box by ecu?
auto bronze crank bush
some sort of trans oil cooler
Auto ecu for the engine
(Auto loom from ecu to the inner wing is part of the main body harness!!! )
Wiring modification to include starter imobiliser to prevent engine start when in drive
Auto dash cluster surround bezel with auto box control lights in + wirng to ecu
Hold/ power switch loom to ecu ( optional )
Flex plate
Flex plate to crank bolts
Bolts for the torque convertor to flex plate
Bellhousing sandwhich plates
Plate for covering hole where master cylinder previously fitted
Balance bar
Cant think of anything else right now. Reason is i have a cunning plan
Edited by Gonzo12c
A task indeed to convert a factory manual zed to auto, will need sone more bits than your list, at the moment I can think of these:
Flex plate
Jeff TT
Thanks alot Jeff will have to look into this in detail as to what is effectively required to make it work and what is not as it would not be on an everyday zed
Ah ive got so many balance bars lol The chrome one is a NA anyway so thats handy with no clutch booster connection on the end :)
Ok so this harness `Auto loom from ecu to the inner wing is part of the main body harness!!!` Is that going from the autobox ecu and to where? I presume its down the left hand side is it all complete with the auto loom for the engine ecu or a different one?
Also i presume this loom will go up to the dash lights somewhere to illuminate the extra lamps for an auto? From what i remember is it about 2 or 3 lamps along the bottom right batch for oil pressure and autobox temp?
Another also with autobox does the oil get cooled aon a heat exchanger effect in with the radiator and would an external oil cooler like a Mocal one be enough to cool the oil by air?
All in though it seems quite possible just need to get it all right before i proceed
Cheers folks :)
Marty
