i saw this looked a bit rough and alot of the space is wasted in the bottom or can you get to that?
to looks of it no its all open on the sides but remember u have the ABS unit on one side so this takes up quite a bit of room ... suppose there's room for tools if the person happen to brake down bit of a faff getting to them
No ABS on my slickie just bags of room. Just thinking about something similar for my build as the plan is to fit 2 10in, amp, 2 nos bottles and 1 extra smaller bottle. Looks to be quite alot of room from the size of that thing. How hard is all this fibreglass stuff to do as i was thinking about just building it myself.
not that hard .. just planning and time
design & Plan
Make Main box/frame
Test fit and align up
First Layer of Cloth to make Front shape
Resin ... Be quick or it will set fast ( dont mix a lot in one go ) about 500mm
wait 3>12hrs to set
Test fit again make sure nothing moved
Start with the fiber glass 3>4layers on the out side and 1>2 on the inside depending on the size
of the area your spanning Make sure there is no flex in it ones its dry
each layer of fiber glass needs to have around 3>12hrs of drying time depending on the mix/brand of stuff
once you have done all this u can rub down so its all most smooth and cover with carpet or
body filler the hole lot and rub and smooth and paint
box that size should take u about week
