car audio lcd
hi does anyone know anyone who can replace a car stereo lcd in the north yorks middlesborough area i have the spare just want it transfering from 1 board to another
needs someone good with a soldering iron as the new lcd is already on a board
prepared to post if any of you lads can do it
It's the sort of thing I might do, can you post up a photo of some of the bits first so I can get an idea of what is involved ?
ok budd will post some pics in a second need the lcd off the green board on to the white one
I'll let Andy say for sure but it looks like you just need to unplug the old boards ribbon cable and plug in the new. Unless you mean actually removing the screen from the board and soldering it onto the other.
the board is a diff fitting although from the same make of stereo budd have already tried thatsome of the resistors are diff also but the screens are identical
Aah well, that's a bugger then.. Andy should be able to sort you out though :)
cheers bud both screens need desoldering and then 1 needs putting on the other board
You got something with a better focus on the bits that need soldering, or is there a pic of the parts online somewhere ? From what I see that looks like a lot of very small connections to re-do !
cheers andy have managed to get the other board working with a few mods things should be ok thanks again though
