help needed
HEllo everybody,
Just bought a 1990 z32 tt (t bar) and realise that the car have these problem and i need help .....
1. prop shaft rattle / vibrates when takes of and hard acceleration
2.air con was running superb but air con compressor cut off after in about 30 mins ( notice amb reads 41 deg) in a traffic jam and only comes back after about 10 mins .
3. What wheel offset are the best looking for standard cars ( not wide body) in 18inch staggered wheels?
4, anyway to repair or diagnose the boost gauge in the speedo (not movin)
Robin
Robin
1. most likely your propshaft center bearing needs replacing
2. amb reading on the side binical is for outside air temprature, press AUTO, then set temp to 10, this will get it out of the AUTO mode see if that helps, if not could be a fault with the airblower ecu
3. +35 front +35 rear offset
4. most likely the boost sender unit in the car (are you left hand drive or right hand drive?) on the UK spec car, its on the left hand side of the vehicle as you are facing it, small black box mounted on the inner side just up from the small fuse box, it has one Vac hose going to it and one connector, change this and you will most likely get your OEM boost gauge working.
ive deleted the other post as it was the same as this one, ive also replied to this one the same as the other one, as this is now in the correct area of the forum, welcome to the club and don't be afraid to ask questions :)
