Electrical Problem
Well my car is at MOT station and its developed a problem
High beam comes on
but not dash/fog/side/main beam lights
any ideas ?
Guessing you have checked fuses.
either both headlights are burned out on low beam, the dimmer switch is bad, the headlight switch is bad
Im assuming is the switch....
Anyone ever made up a UK standard Fuse box cover insert? that cold say be printed, laminated, and stuck in the fuse box with a bit of blue tac, so as not to ruin the existing JDM pedigree of the car?
ok ... changed a 10amp fuse and all my lights are working ... but i dont have any water temp/boost/oil/fuel working on the cluster ?
i'm a dip shit .. i stuck one of the fuses bk in the wrong hole when testing them all ... working now
Edited by MarkDerby
You could print on card or have a photo developed of this and stick that in there
I just automatically assumed by your signature you would of checked fuses first - :s
Bet your glad! The fact ur at an MOT station, I also thought they wold of guessed that lol. I'd change my local garage If I were you lol.
thought it was strage ... i was thinking that the MOT station had done something .. but to have all lights/dash/indicators .. not working thought more on the lines of a relay ...
and me being at work and running bk forth to stations ... all bit of a panic really
i did replace the fuse just before i got a reply on here but as the lights worked then but no dash ... well
some times the simplest of things can catchs all out :)
Plus im really ill today and didnt get much sleep last night due to Burning temp and shivvering like i was cold
bad chest and a body that feales like a dead weight ... no wise cracks about me being fat :)
so take that into account
Mark :)
lol mark, not blaming you mate. garage should of picked up on it, I might of been in a tizzle if it happened to me, but garage have nothing to lose, so they shoould of known.
glad ur sorted.
nice install btw, but where u put ur shopping? wifes car I guess?
omg, what a plan, big ice install in boot = no more shopping trips, all have to be done online lmfao.
wifes car ... ha i wish the only thing she drives is me up the wall ....
we have another car for normal day to day
