Rain.........=.............leaking roof........
Help............
Targa leaking.....looks like at join between targa and shell joint..fairly common problem..what is the best remedy....this is ruining my seats and and tops up the A-pillar gauges...this is really beginning to piss me off.
Many thanks
Regardz
Last summer I put Autoglym rubber treatment on the seals. I also found 2 drain holes in the rubber seals that had shrink a little.
It felt strange doing it wink.gif but I covered it rubber treatment and spent 5 mins putting my finger in and out of the holes. It streched the holes to is original size and after that my didnt leak. Its just started to now and when it stops raining I am gonna try it again to see if it was a coincodence. (sp) wink.gif
Stuart
Just as well Nissan don't make submarines....
Chech the drainage holes aren`t blocked. get a 4ft pipe cleaner and clean them out!!
Cheers yet again.........will be trying the above remedies...see what happans!!!
Regardz
I treated my ones with the autogylm rubber treatment. My roof has stopped leaking for now. I will put another coat on when I get chance
think a friend of mine can get the full replacement rubber/seal kit for about 80 quid if anyone wants em?
if you are interested then let me no and i'll see if he can still get em.jay
Drain holes in the rubber???
I have spotted the drain holes (pipe that runs down to inner wing) I will clean these out are there other ones in the rubber???
If this fails (jaylox) will def be interested in buying the new seal set.......
This problem pisses me off more then any other snag I have had!!...prob cos cant trace it!!!
Regardz
