resister mod for the speedo
does anyone have a picture of the resistor that needs swapped and what value of resistor do I need to get? thankyou to do the mph conversion properly and also what is code 34,
Don't know about the resistor but code 34 is knock sensor i.e. it's got a problem with either the loom or it's broken.
The resistor is at R10 on the speedo circuit board, will try and dig out the info, but you also need to re calibrate the speedo using the pots on the board.
That would be very handy if you could find the info mate, something i've also been meaning to do for ages as my kph/mph converter has always played up, plus when I put the NA rear end on, gonna have some fettling to do to it...
thanks for the reply's and that info would deffinatley be handy for the speedo
I know the info link for the r10 mod but thought this only did the kph adjustments
